Hello, i have been using brave for a while, however i regularly have a problem with my browser freezing between 2 to 12 seconds.
for example I write a text and well everything freezes but the keyboard continues to function.
the same if I watch a video, the image freezes, but the sound continues and after 10 seconds the image is updated.
do you have this problem?
thank you
Check whether the issue persists in a fresh user profile.
Can you please provide the information that was requested in the editor?
Guidelines - Before posting, please:
- Search the forum to see if anyone else has already posted or resolved the issue you came to ask about.
- Fill out the template that appears in your editor when posting as it contains all the boiler-plate information surrounding your issue. It will help the Support team members and other Community members to efficiently assess and resolve your issue.
- Provide essential info such as your version number and OS, to help Support and other Community members resolve your issue.
- Ensure that you’re posting in the appropriate category
- Tag your post appropriately – note that some tags are restricted to or from specific categories.
- Observe and adhere to our code of conduct
