yo brave has become unusable for me it freezes up very often while everything else is working fine its not a ram or hardware acceleration issue and i cant figure out whats causing it. im on the latest standard release
Hey @CathRtic ! Welcome to the community
Do you have any extensions installed? Can you try disabling them to see if performance improves?
If not can you please take a screenshot of the built in Task Manager (found in Menu Icon → More Tools → Task Manager) and open any of the processes that have sub processes.
Thank you,
Porridge
also i just removed ublock origin and Grammarly extensions to see if that helps
You have a large amount of tabs open, can you try exiting your browser completely to see if anything changes with your experience?
Porridge
ive compeletly closed everything before lowered the amount of tabs and still freezing, and even with the large amount of tabs my cpu or memory is never maxed out and i have used it like that before for a long time so im highly certain its not that
Can you try disabling all your extensions to see if it makes a difference? I see you have 10 other extensions not including Grammarly and Origin.
Porridge
ok that worked ill go through each extension one by one to isolate which ones are causing it
