Two sites that will not load, riffusion.com and covertdrones.com (SOLVED) It was my VPN
riffusion.com and covertdrones.com only produce a white screen. The favicons load. Both sites function just fine with librewolf browser. I am using the latest brave release on default settings on a Windows 11 desktop. I have turned shields on and off. I have gone through and individually turned everything I can find on and off. Nothing works. Just the same white pages.
Any assistance would be lovely.
I also tried Brave Beta and its the same.
(My Solution) It was an issue with my VPN all along. I changed it to use Obfuscated Servers and that fixed “my” issues. It also solved an issue with Reddit telling me to login to read or post. I hope this helps someone else :slight_smile: However, I still find it odd that it was only an issue with Brave and not my other browsers.
@4Doose both seem to load perfectly fine for me. Have you tried visiting the sites in private window? I’m kind of wanting to assume it’s either extensions or cookies.
I feel a bit foolish now. It was NordVPN. I switched to Obfuscated Servers and it fixed almost every issue I have with any website even Reddit. Im going to edit the title in hopes that this might help someone else.
