I searched on the internet, and I believe it’s something that happens sometimes, but I never had this problem before some of the last update. The search bar doesn’t disappear when I scroll down anymore. Before, it happened sometimes but closing and reopening the app was enough, now it doesn’t work anymore, it’s fixed down. I believe it’s due to the overlay of another app, but I can’t turn it off just to have the bar do what it’s supposed to. Please fix it?
Please edit your Original Post (“OP”) above, in order to include:
- Brave Browser version numbers
- Operating System version numbers
- IF using an Android device - brief description of it
IF you are using a mobile Apple device (re iOS), then consider:
