Rewards not synced between all devices
Briefly describe your issue:
I Am running brave on 2 windows pc and 1 android devince. Everything like history bokkmarks etc have all been synced except for the rewards . The balance is deffernt on my androind device that it is on the pc desktop browsers
Windows and android
Is your Brave Rewards Profile currently verified? (yes/no)
All 3 are fully verifies
Are you using a VPN? (yes/no)
Have you manually turned off Auto-contribute on all of your devices?
This is actually normal and how it works. Sync is only for as you mentioned settings and whatnot, however, rewards are separate. each device has it’s own unique wallet ID and is not shared across each device. IF both devices are connected to the same custodian account such as Gemini or Uphold, then the total balance possessed in the Custodial account will show on both devices but that is it. Hope this helps.
