Brave rewards not synced on seperate synced devices
**Briefly describe your issue:**I am using two seperate devices alternately. Although device sync has been set, brave rewards are different for each device. I would assume that by syncing the reward totals should also sync.
**What Operating System and Brave version are you using (Menu --> About Brave)?**Both machines run lm 21.1, brave version 1.46.144
Is your Brave Rewards Profile currently verified? (yes/no) yep
**What date did you connect a your Brave Rewards Profile?**recently approx 2 months maybe
**Have you been able to successfully receive payments in the past?**na
**Are you in a supported region (see here for list of supported regions)?**yes
**Have you manually turned off Auto-contribute on all of your devices?**I am receiving bat on both machines but the totals will not sync!
@ekarnots You’ll see in your options for things to sync, BAT/Rewards isn’t one of them. The only way you can “sync” them so-to-speak is to connect them all to Uphold or Gemini, at which point all payments will be collected there and total balance be displayed.
