Accumulated Rewards not the same between mobile and desktop
I’m a new Brave user (just a couple weeks) and don’t really get how all this BAT, Rewards, etc stuff is supposed to work, but it seems like if I have sync set up (I do, mobile (v 1.19.86) and desktop (1.18.77) instances on the chain) then the displayed Rewards should be the same on both. I show 0 BAT on mobile and 2.53 BAT on desktop. Shouldn’t this be a shared value?
I see nothing obvious when I fumble around in settings. The only thing I can think of which might be an issue is that I run pihole on a Raspberry Pi. Might it be blocking some necessary traffic?
Edit: After seeing a mention of SafetyNet in another thread regarding Android, I downloaded and ran it on my Pixel 3. It passed.
Brave Sync don’t sync Rewards data. :man_shrugging:t2:
Thanks for that clarification. Still, shouldn’t the rewards shown on both Android and Desktop match? Maybe there’s some other way the two should be connected? A login I’m missing in some way? It seems a bit crazy that rewards accumulated by the same person on multiple devices wouldn’t be aggregated into one lump.
You can connect up to 4 browsers wallet to Uphold. https://support.brave.com/hc/en-us/articles/360034841711-What-is-a-verified-wallet-
It’ll sync the total balance.
Thanks. Looks like I’m on my way.
