- Previously opened tabs not re-opening when opening Brave even though this is
“on” in the Settings (On Startup “Continue Where You Left Off” is checked).
**Expected result: Please tell me if I need to tweak something to fix it or validate that I’m not crazy, it’s a real bug, and you are working on it.
**Brave Version( check About Brave): 1.74.51
Thank you!
