The fonts of some sites, including social networks, appear kind of serilla, almost transparent.
Steps to Reproduce:
Just open this site: https://favaretoufabc.wordpress.com/
Fonts should be normal.
Always.
Windows 10 x64.
Brave Version 0.63.48 Chromium: 74.0.3729.108 (Official Build) (64-bit)
Apologies for late response @phrmendes.
Can you try disable “Hardware acceleration” under Brave’s Settings > System? And see if it can solve you issue.
Thanks,
The site displays fine for me on macOS and Windows systems. Do you have any extensions installed?
The site displays fine for me too when I’m using Linux Mint. I have extensions installed, but I tried without them and the result is the same.
@phrmendes,
Thanks for the information – I’ll have to dig into this further. Appreciate your patience and will return when I have more information.
Thank you very much for your attention!
@phrmendes,
Are there any other example sites you can share where you see this same type of issue?
