I frequent piracy websites to watch anime and movies on my iPad. These sites, two in particular, bypass the shield quite easily in terms of popups that open up external sites.
Turning on the script blocker will fix the issue but it breaks the site - the video player becomes unresponsive.
Any fix for this?
ffmovies.sc, tvshows88.com, 9amime.ru
Yes.
With adblock off I guess it DOES function as it should - jampacked full of pornographic ads, popups, malicious malware and the likes.
Enabling “block scripts” will break the site.
On my PC, all these sites are awesome using uBlock with Chrome.
1.26
