Adds are not blocked while I’m using brave
Description of the issue: Adds are not blocked, I get redirected to another website
Exact URL of the website in question: streaming films sites - https://vv1.french-stream.is/serie/15107181-them-saison-1.html
Does the site work as expected when using Chrome? no, because chrome doesn’t block adds
Hello @Jellzz206
Thanks for the information and sorry to hear you’re having trouble with blocking ads. Our best recommendation is to use this link you can block ads using aggressive mode.
Let us know if that helps.
Many of these pirate streaming sites uses randomised domains to serve ads/popups. Hard to counter on ios.
No it doesn’t work, adds pops up even with the shield activated
Adds used to be blocked before idk why it doesn’t work anymore
