i have everthing correct but today everything and everything got deleted
i recovered my passwords (not all) from a password export and then imported it back but everything is lost and not all my passwords are back :((((
is there any way i can get them back
Hi @MoDz,
Do you know if you’re using multiple profiles? Do you have a circular icon in the top right? If so click on that icon and you can navigate between profiles.
i had many profiles they all gone its like i just downloaded the browser
Can you navigate to:
Users\YOURNAME\AppData\Local\BraveSoftware\Brave-Browser\User Data
In the User Data folder, do you see a Default file? and a Profile file?
yes i have that file
Can you list all the Profile files you see? or how many do you see?
Can you go to brave://settings/clearBrowserData, do you have anything under on exit ticked?
