Fix to Brave crashing after CTRL+V
Description of the issue: Brave crashes when pressing CTRL+V to paste text.
Steps to Reproduce:
1. Get text to the clipboard by using CTRL+C (Does not make the browser crash
2. Select a text box or the omnibar.
3. Paste the text by using CTRL+V
Actual Result: Browser shutdown.
Expected result: Paste the text flawlessly.
Reproduces how often: Always when pasting.
Operating System and Brave Version: Windows 10 Pro,Brave 1.85.118 (Official Build) (64-bit), Chromium: 143.0.7499.169
Additional Information: Does not happen when using CTRL+SHIFT+V
The fix found:**
Remove the Paste shortcut entirely. (Can still paste text)
Hope this helps anyone with the problem.
First time using Brave community, I don’t really know these are the correct tags or whatever. Hope it helps someone.
