Fix for BAT not porting to Uphold wallet
Dear Brave Rewards Users,
If you’ve experienced an issue with BAT not successfully porting from your browser wallet to your Uphold wallet, please upgrade your browser to v1.22.67. Once upgraded, then disconnect and reconnect your Uphold wallet. BAT that was earned before the March Rewards Settlement should then drain directly from your browser wallet to your Uphold wallet.
Thank you for your patience as we’ve worked to implement this fix.
The Brave Rewards team
We’ve received reports of this working for some users and not working for others. If updating to 1.22.67 did not drain your BAT earned before March to your Uphold wallet, please send me a DM with the following info:
  • Wallet ID (brave://rewards-internals/)
  • How Many devices your have linked
  • Date that wallet was verified
  • Screenshot of your rewards panel
Thank you in advance!
The team is still investigating why this did not work for all users. Thank you for your patience as we work to get to the bottom of the issue.
This is still a known issue that’s being investigated. We appreciate your patience as we continue to work on a fix.
