Dark mode not needs to be reset every time I launch Brave
  1. every time I launch Brave the Dark mode is not showing (in a blank window Cmd N) I go to settings and it says Dark. I have to select another option like system then select Dark again and it will stay Dark until the next restart. Thank you
Expected result: Dark mode even with restart
Brave Version( check About Brave):1.84.135
Additional Information: Mac OS 15.7.1
Check out this thread and this post, click the arrow down to the right or header link, I think it’s the same issue:
The same thing started happening for me after I updated to 1.84.135. I set appearance to Dark Mode. When my computer wakes up after an overnight rest, it is in light mode even though it is still set to dark mode.
Mac 15.1.1
