Troubleshooting technical issues is much easier when both the user and support agent practice clear communication. For this reason, we have provided the template below for Description of the issue: Possible Brave Looses Passwords?
Using Brave (Brave 1.84.135, Chromium 142.0.7444.135) on a LG Gram laptop with Windows11. Unless I do something wrong Brave to my opinion does not always keep saved passwords. To try, yesterday I open the Amazon.ca Tab and went through the process re register my login, passwords etc and eventually I got access to the site. I did the same for Amazon.com. After I login to each site a small window comes up to save password etc and I click ok. Today trying to login to the same sites they are asking again to register! When I go to Brave password manager, to get access to it I have to type my MS account password but nothing happens. However I do have other Tabs which work like they should, I click the Tab and the site opens and I’m logged. Any idea what is wrong? Many thanks for your time.
Operating System:
