Passwords keep being deleted and all sites logged out
The browser keeps losing all my saved passwords and logging me out of all websites (deleted cookies) What can be causing this?
Windows 10 Professional, Brave 1.80.115 (Official Build) (64-bit)
I have no idea what this means. I am just trying to get support for this browser. Who is your verified custodian or self-custody? (Uphold/Gemini/bitFlyer/Solana)
I am in the USA
@pcs800
Things to consider:
Open issue at Github > Brave
Users being logged out of sites when closing the browser (on Windows):
‘All accounts (Google) getting logged out automatically - #3 by Mattches’
Something(s) might be banged up / wounded inside a User Data folder (Brave-Software folder: Linux OS, MacOS), and the user might try to piece together a restoration - using pieces from their browser data backup (that we hope, the user has been routinely making). At the following link, scroll down to “There are some key files I can share”:
‘Brave doesn't start when I run it as administrator and Brave Shield doesn't work - #73 by clifton’
My own two cents:
Windows OS > Brave Browser users > User Data tips re backup, permissions, recovering or restoring some of the data:
Windows OS users. Brave Browser data is within the folder and sub-folders of the User Data folder; location:
  • C:\Users\[UserName]\AppData\Local\BraveSoftware\Brave-Browser\User Data\
Also written as:
  • %LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\
Let us say that you have backed up the User Data folder to a safe location - away from the BB installation paths, such as: on an external USB drive.
Next, because of some issue with BB, you decide to set aside the User Data folder - ie remove it from location:
for the moment, placing that User Data folder on your Windows Desktop; and then Restart the computer; and then Start up Brave Browser . . . BB will create an entirely new User Data folder that will include a fresh, new Default folder:
  • %LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Default\
Let us say, that you previously had 2 additional BB user profiles. And, you want to try and restore what you can, from them ← therefore, create 2 new additional BB user profiles ← their respective new folders (Profile 1 folder and Profile 2 folder) will be created at:
  • %LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Profile 1\
  • %LOCALAPPDATA%\BraveSoftware\Brave-Browser\User Data\Profile 2\
From the backup of the User Data folder that you created (and may also located on the external USB drive ← smart move!) -OR- from the User Data folder that you placed on your Windows Desktop . . . and while BB is NOT RUNNING after a Restart of the computer, there are some items that can by drag-copied (I am not a fan of Copy-and-Paste method) from the old (backed up) data location to the new.
SOMETIMES, you might succeed by “simply” replacing the new Default folder with the old ← BUT THAT MAY NOT PRODUCE THE RESULTS THAT YOU EXPECT / WISH.
BB PROFILE data, within a BB user’s profile folder (Default example):
The following list of items, are known for being replaceable - BUT AGAIN, NO GUARANTEE OF SUCCESS:
  • Bookmarks [JSON file]
  • History [SQLite file]
  • Login Data [passwords, SQLite file]
  • Preferences [majority of browser settings, JSON file]
  • Sessions [folder ← do not copy]
  • [but you can copy the Sessions and Tabs files:]
  • Session file example: “Session_13387619522050810” [SNSS file]
  • Tabs file example: “Tabs_13396004968468207” [SNSS file]
  • Tops Sites [saved tiles on new tab page, SQLite file]
  • Visited Links [binary file]
  • Web Data [autofill data, SQLite file]
NOTES:
Re Session_13387619522050810 ← the long string of numbers are a date-and-time stamp. On a MacOS computer, the following command (date -r 13387619522050810) will reveal: Thu Apr 6 12:40:10 EST 424238744
A Profile 1 folder, for example, cannot be replaced by a profile folder of another name (such as Profile 2). Same for the other BB user profile folders. DO NOT CHANGE the BB user’s profile folders names.
IF you have not changed the Brave Browser (“BB”) user Profile names, THEN:
  • BB user Profile named “Profile 1” data is in folder named “Default”
  • BB user Profile named “Profile 2” data is in folder named “Profile 1”
  • BB user Profile named “Profile 3” data is in folder named “Profile 2”
That pattern applies to all Brave Browser Linux OS, MacOS, and Windows OS users.
SOMETIMES: A BB user has recovered passwords by using the backed up Login Data file; and sometimes by doing that PLUS using the backed up Local State file; and sometimes by a combination of: Resetting the Brave Browser Settings, using the backed up Login Data file, plus, using the backed up Local State file.
FILE AND FOLDER PERMISSIONS - See:
  • https://community.brave.app/t/browser-wont-launch-after-install/606342/18 and
  • https://community.brave.app/t/brave-doesnt-start-when-i-run-it-as-administrator-and-brave-shield-doesnt-work/628494/41
RECOVERY, RESTORATION ← MUCH DEPENDS UPON:
  • Maintaining routine backups of the User Data folder (Windows OS)
  • Maintaining routine backups of the Brave-Software folder (Linux OS, MacOS)
  • System Restore Points (Windows OS)
LOCATION of BRAVE BROWSER INSTALLATION
With Brave Browser running, in a New Window, go to brave://version and scroll down to:
  • Executable Path
  • Profile Path
Strict guidance for remaining logged in:
`Sign In to Outlook.com website is not being remembered - #2 by 289wk’
A simple “go to this folder C:\Users\Eric\AppData\Local\BraveSoftware\Brave-Browser, and rename the User data folder, then Brave will start as a new installation” would have been great.
This is the strangest forum I’ve ever used.
I’m facing the same issue. Today I got logged out from all the accounts and my passwords got deleted from password manager. I’m using Linux. Thankfully I got the backup from my mobile phone otherwise I have lost access to many of my accounts. There is one issue also, the passwords are not synced automatically for newer accounts created. I noticed when I visited the website that there was no autocomplete on the password. Fortunately I got access to my email account and could ‘Forget the password’ from the website.
Hope devs solve this issue. Currently the version I’m using is ‘Brave 1.80.125 (Official Build)(64-bit)’.
@Mattches
Please see the reply by @cAMPer :
‘Passwords keep being deleted and all sites logged out - #4 by cAMPer’
Apparently has Brave Sync enabled, but lost passwords on desktop (Linux OS). (Did not lose passwords from mobile phone.)
