Block Element is missing from Brave Shields menu
Description of the issue: Is it gone in purpose and will it come back?
  1. Open new redesigned Brave Shields menu via omnibox
  2. Notice how Element Blocker is missing from the menu
Expected result: Element Blocker should be visible
Brave Version( check About Brave): Brave - Nightly 1.93.40, Chromium 149.0.7827.59
Mobile Device details
It’s in the context menu as it has always been:
Im on android, not pc. It used to be in this menu but now its gone. I checked chrome://flags and block element flag is still enabled.
Apologies – for got which category I was looking in.
That said, it’s because you’re in private browsing – the Block elements feature is not available in private by default and has been this way. You can see this by opening a private tab in previous builds – Beta or Stable at the time of writing this – and observe that the option is gone from the menu there as well.
If you go to Settings > Brave Shields & Privacy you can toggle on the Allow element blocking in private windows option which should resolve the issue.
I have that option also turned on, still it wont appear in the menu.
Ahh I see – you’re right. In Stable and Beta the option appears but it looks like in the latest Nightly that option no long works. Reaching out to Android team now.
I’ve filed this issue and the devs have identified the problem – will likely push a fix tomorrow or by mid week:
