Block Element is missing on my dekstop Brave.
Right click on page should show Block Element option
what happened instead:
EDIT: Also I posted my screenshot from ibb as it is the first google result for “temporary upload embed image”. It is supposed to auto delete after 6 days but it delete itself now. huh
I search forum just in case, @S7evin point out that BE only available when shield up. I’m pretty sure my shield is up most of the time but even in this forum, BE doesn’t appear for me
1.79.126 Chromium: 137.0.7151.119 (Official Build) (64-bit)
I don’t disable update (yet) so this should be the latest
- I don’t know if i have disabled it somehow. The only thing I remember disabling from Brave was something as response to Google disables users from using adress bar as search bar.
oh I found it. somehow i disable it in Shield> Trackers and ad blocking. ugh
July 2025
“I don’t disable update (yet) so this should be the latest”
Now they push Open New Tab from context menu 3 rows down. I told you brave would f things up. This is why users want option to disable update
