Blocking and removing Element no longer working from Brave control
Disqus notification page for my account used to allow me to use Brave to pick an element and get rid of it. Now I go to the brave icon scroll down to remove element go through the process there is literally nothing in the box where there used to be code when I had picked an element and move to have it removed.
  1. By going to The disqus notification page I’m going through the process of using Brave to block an element.
Expected result: element doesn’t come back when using the same page again.
Application version
Brave 1.85.112, Chromium 143.0.7499.52
Operating system
Android 16; Build/BP2A.250605.031.A3
Mobile Device details s24 Plus. Completely up to date as of this date today.
Additional Information: thank you
@Silat
Suggested reading and a lot of study; click the link and read there, and on down the page (there):
Yes thank you for all that information. I don’t say this sarcastically but I know all that. There is literally nothing created in the filter box when I use Brave. It used to have the syntax in the filter box and then you said save and then it continued to work at leaving that element off the page. Now there is no syntax in the filter box.
It seems like you’re specifically having issues with a Disqus site – can you please confirm whether or not the Block elements option works as intended for other websites?
I understand that it would seem like I’m only having a problem with one place since I didn’t mention others. I just went to about 20 different sites randomly and tried to dismiss an element the exact same thing happens. I go through the process and the box that usually has the syntax is empty no matter what element I try to get rid of on any random site.
Does the element actually disappear from the site still?
No the element does not disappear. I think that the fact that there’s no syntax in the Box would mean that the element wouldn’t disappear. Because when you go to the box you see the syntax under normal circumstances and then you click save and that’s when the element disappears.
@Silat can you please update to the latest build (v1.85.116) and tell me if the issue persists after the update?
Hello. I rebooted the phone rechecked for updates for the phone none are available. Went to the Play Store saw the new update for brave. Installed. Rebooted the phone. Even clean the cache on Brave.
Same issue and I attached to jpeg just to make sure you see what I see. Thank you for helping
(attachments)
Can you try downloading the Beta app from the app store (this will not overwrite your current install) and test to see if you get the same issue in the Beta?
Good evening. I just got the message and I just finished installing the beta and sadly exact same thing. Again thanks for trying to help. I really do appreciate it. And I want you to know you know it works perfectly fine till about a week ago or so could have been a few weeks.
Not going to lie, I’m truly surprised that the Beta is showing the same behavior. That’s really strange – especially since you’re using a fairly common type of device (S24+) and the block elements feature works fine on my S22+.
I’ve asked some of our Android folks to take a look. To clarify, everything else in the browser works as expected?
Yes the only thing I’ve noticed is the element issue. Thanks again.
(attachments)
Can you confirm whether or not manually typing in the filter and clicking Save changes doesn’t work? For example, if you type in:
community.brave.app###site-logo
And tap Save changes does this block the Brave logo on this site (community.brave.com)?
I can confirm that when I press save with the provided syntax it does work. My problem is that I don’t know the syntax to get rid of elements and previously when I went through the process to get rid of a element the syntax automatically appeared in the box and I press save and it disappeared after a refresh. Now nothing appears in the Box and even if I press save and refresh the element does not disappear.
Is there any chance that the brave Engineers are working on this issue?
Anything?
Is there a chance?
Anybody home?
@Silat sorry for the long wait time here. Many of our employees – including the devs I was previously talking to about this issue – are still on holiday PTO.
Most of the team should be back next week and I will make sure someone takes a look at this. In the meantime, I would be curious to know if the Block elements feature works in the Beta version of the browser? You can download the Beta from the app store. Note that installing/running the Beta will not overwrite any of your current Brave installs data – it will just run as a separate app/browser.
Try installing the Beta and test the element blocker there and let me know you see the same issue.
Hey thank you for getting back to me. Yeah I don’t begrudge anybody being on vacation. Anyway if you follow the thread I’ve been in I’ve done all those things already. Installed the other Brave version and no it doesn’t work there either. You know I really do understand computers and software and such and I know that sometimes on some something changes and it doesn’t work for everybody. So just so you know I’m not unhappy or throwing a fit.
(attachments)
@Silat apologies – it was even me who had already asked that previously :upside_down_face:
I’ll try and do some digging around on this but will likely have to wait for some of the Android folks to get back and have them take a look.
