All search engine options gone and only Brave Search remains
Hi!
My Brave browser has removed all search engines, except for Brave Search
And when I go into “Manage search engines and site search” I can’t add any additional engines, only edit the Brave search
Brave browser version: v 1.86.146
Windows version: Windows 11 Pro, build 26200.7628
@ste_wilko
Try . . .
Create a new user Profile for Testing:
Create and use AN ADDITIONAL Brave Browser user Profile (Menu --> More tools --> Add profile) - only ← meaning: Do not have any other Brave Browser user Profile tabs/windows open.
When creating this new Brave Browser user Profile for test purposes
  • Do not import anything.
  • Do not add any extensions.
IF this test Brave Browser user Profile does not present your problem, then possibly, the profile that you have been using, has a problem . . . and that might be caused by one or more extensions, or too many tabs ← complex/conundrum.
Detailed info about testing - IF, in regard to memory and performance issues:
Create a new profile to help Troubleshoot
‘Where Brave Browser Profiles Are Located’
This issue has actually happened before but was fixed quite a bit ago:
Let me ask some of the devs to take a look here.
I did this and the new profile had all the search engines, as expected
This doesn’t have a method to fix, other than to upgrade to a version that has been superseded by my current version
I had this happen some time ago randomly, around the same time I lost my sync chain from my desktop to..the chain. But then one Brave update later, it came back.
It’s ironic though the GitHub post is closed months (more than half a year honestly) before I ran into the issue (which I think was only just a few weeks ago). No solution was provided to me until it just came back on its own after an update, which clearly re-wrote some corrupt file.
Right, which like me, means it’ll reappear on the next Brave update.
I think Local State or Preferences gets corrupt, and somehow updating Brave fixes these issues. (That’s my opinion on it at least).
It’s definitely something to do with the profile. I created a new one and copied everything over from my old profile and the problem persisted.
So, to fix it, I’ve created a fresh new profile :man_shrugging:
@ste_wilko I was simply pointing out that the issue had occurred before and should have been resolved. I will reply back here when I hear back from the devs about this.
The Github post infers it was fixed last year, but clearly (and you were there) in 2026 it was not in fact fixed.
