Again - Click'n Load for JDownloader in Brave leads to error
Hi there,
I’m on Brave since 2 months now and it’s great!
But since (was it last update? Don’t know exactly) the Click’n Load option from filecrypt.cc leads to **”Links could not be submitted.” **
It worked since I started using Brave - but now I see this error.
No luck so far. When I download the .dlc and add this to JDownloader it is working.
If using Chrome → No problem.
Any idea what to do?
Thanks and regards
@AlBundy00001
You might test by installing only that JDownloader extension - installed in a separate Brave Browser user profile.
Create a new user Profile for Testing:
Create and use AN ADDITIONAL Brave Browser user Profile (Menu --> More tools --> Add profile) - only ← meaning: Do not have any other Brave Browser user Profile tabs/windows open.
When creating this new Brave Browser user Profile for test purposes
  • Do not import anything.
  • Do not add any extensions - other than the test extension.
IF this test Brave Browser user Profile does not present your problem, then possibly, the profile that you have been using, has a problem . . . and that might be caused by one or more extensions, or too many tabs ← complex/conundrum.
Detailed info about testing - IF, in regard to memory and performance issues:
Create a new profile to help Troubleshoot
Multiple Extensions Tests:
  • test by disabling all extensions
  • test by enabling each extension individually
  • test by uninstalling all extensions
  • test by installing each extension individually
  • test combinations of extensions
  • test order of installation of extensions
Thanks for your hint - I already did this. Does not change anything.
Same link with Chrome is working with Click’n Load - Brave shows error.
Funny thing is: When I download the “.dlc” file it opens in JDownloader. But NOT the Click’n load.
I can live with it - but it worked (my guess) until the last update with Click’n Load.
I am not seeing what you’re seeing but I may be misconstruing the route you took to get this issue.
Can you please provide the exact steps taken to produce this error so I can test on my end?
I had the same problem. It was working in Chrome and Brave but stopped working in Brave a few days ago.
I had to set “Allow” for “Apps on device” in the site settings and now it is working again, even with Shields up and “Local network” set to “Ask (default)”.
The fact it needs localhost access seems unusual.
Not sure what you mean. Can you please provide more details or a screenshot?
I’m from Germany and using german version of Brave.
Current experience for me (strange!):slight_smile:
Click’n Load:
Then it takes ~10 seconds an then switches to “green” and appears in Jdownloader.
After that a reload of the site comes to “green” at once with Click’n Load.
I’m confused…
Too early:
This one is running forever: https://filecrypt.cc/helper.html?1774035257899
Spinning wheel top left does not stop…
Wie der Zufall so will bin ich auch aus Deutschland. Nutze Brave normalerweise in Englisch aber hab es mal auf deutsch umgestellt für die Screens. Letztlich ähnlich wie in der Anleitung auf der JDownloader Seite, nur die Einstellung Apps auf dem Gerät, statt Lokales Netzwerk wählen:
For everyone else, I just activated “Apps on device” instead of “Local Network” as suggested in the Knowledge Base article on the JDownloader page. That did it for me. I don’t need to set “Local Network” or deactivate Shield.
