Hy everybody. It looks like BB is not forwarding any request to Jdownloader. I installed the plugin but it doesnt helped
Are there other ways get it working?
First, welcome to our community forum! ![]()
To your question: I had the same problem and the solution to it was easy too. You need to deactivate Brave Shields temporarily.
Important: Depending on which site you’re, you need to activate
Brave Shieldsagain before leaving. In my experience the next site I opened, same site but with other links didn’t load correctly because the ads came across your way. So the first time you need to open it with activatedBrave Shields. Then after the site is loaded deactivate it and use theclick'n'loadbutton. After that activate it again.
Short Guide:
Brave Shields is activated. (Lion is Orange, else gray)Click'n'Load button.Brave Shields.Click'n'Load button and add the links to JD2Brave Shields again.
