- YouTube videos do not display properly on certain monitors when using Brave. (multi-monitor support)
- I did not have this issue before my last update.
When trying with Shields down, the ad before the video behaves the same way.
If I open the settings menu (gear icon) and then playback speed. the video displays as long as the menu is open. - holding the mouse over the timeline display properly displays the thumbnail frame for that moment.
- This issue does not occur in other browsers like Chrome or Edge.
Launch Brave
Navigate to YouTube
stream a video
Move the Brave Window playing the video (or paused) to a different monitor screen.
Video should continue to play normally
Actual Result (see screenshots):
After I open the YouTube video on my Auria EQ278C monitor the video plays properly. when I move (at least 50% of) the brave browser window to my Asus XG32AQ or Asus XG32VC monitor the video image turns white. I do see “watermark link icons” in the video but not the video image itself. the audio plays normally.
Reproduces Consistently?
Yes. Since last brave update.
Brave: 1.83.112 (Official Build) (64-bit)
Chromium: 141.0.7390.70
Processor AMD Ryzen 7 5800X 8-Core Processor (3.80 GHz)
Installed RAM 32.0 GB
OS Edition Windows 11 Pro
OS Version 24H2
OS build 26100.6725
Video card: NVDIA GeForce GTX 1060 3GB
Display 1: Asus XG32AQ (YouTube videos display as all white)
Display 2: Asus XG32VC (YouTube videos display as all white)
Display 3: Auria EQ278C (YouTube videos display properly)
