Description of the issue: Brave Ad blocker no longer blocks Youtube’s ads when the settings are set for Ad blocking: Standard and on normal viewing (Not private browsing).
Exact URL of the website in question: Youtube.com
Did the issue present with default Shields settings? Yes
Does the site function as expected when Shields are turned off? Yes
Does the ad appear when using a Private window as well? No ads appear when using private window (The ad blocker is working in private window)
What OS are you using when you see the ad? Windows 11 | Ver. 24H2
Brave version (check About Brave): 1.84.139 (Chromium 142.0.7444.163)
