@andy9@shantanu can you both please tell me what the actual error message (and/or behavior) shown when you try to view DRM content? For example, If you go to Netflix right now for example and try to stream something, can you share a screenshot of what you see?
Perhaps this helps? The following console error is showing on Netflix in Dev Tools. This is on Brave Nightly where I have no extensions installed.
Warning – I suspect not relevant but sharing all details.
com.microsoft.playready.recommendation.3000: Internal testing is highly recommended prior to enabling PlayReady playback on Windows. Failure to do so may cause application instability or playback errors.
Before generating a request, setServerCertificate() must be called with a valid server certificate. Otherwise, generateRequest() could fail.
Error
$Va: undefined
IJ: undefined
Qga: undefined
YVc: undefined
alert: undefined
code: 7702
data: NotSupportedError: CreateCdmFunc not available.
details: “CreateCdmFunc not available.\nNotSupportedError: CreateCdmFunc not available.”
@andy9 The information you’ve provided so far has been very helpful. I am opening an issue for this now and having the team investigate. Appreciate your patience.
Unfortunately nothing substantial but we do have an developer looking into the issue presently. @shantanu OP shared that Beta/Nightly also showed the same issue – would you mind testing the Beta build on your end as well just to confirm that WidevineCDM isn’t working there as well?
