When Shield is on https://fmovies.to/home can't load
Hello, hope everyone is well.
I’ve found and issue when Brave’s Shield is on, https://fmovies.to/home can’t lot anything, Then when I turn off Shields the site works fine, but I don’t know if I want to leave Shields off,
Yes it is still present
Yes the site works normal when Shields is off
This I don’t know,
Yes site works fine with no Ad blocker
1.43.88
Hi
On my side also, the site only works with Brave shield OFF; But by openind Dev Tools, it appears that a widget is blocked by the shield (https://s7.addthis.com/js/300/addthis_widget.js ) , but this is needed to contact a server in order to play the movie. It seems that this widget is safe. In addition to this, no ads show up when shield is off.
Thanks for the link!
Fix on its way, give it 24hrs.
