When attempting to install the Vysor Chrome extension with the Brave shield disabled I am receiving the error message: ‘WebGL is not supported.’
- Go to the Vysor Chrome extension.
- Disable the Brave Shield.
- Select Add to Chrome.
Vysor Chrome extension downloads successfully.
Every time Vysor is attempted to be downloaded and installed.
Brave Version(about:brave):
Version 0.57.18 Chromium: 71.0.3578.80 (Official Build) (64-bit)
yes
