I would like to make my instance of Searx the default search engine, however the option is greyed out for custom search engines. Is this intentional, and are there workarounds? It seems silly that a privacy browser would force you to use baked in defaults.
system
Closed
2
Related topics
Topic | Replies | Views | Activity | |
Can't set ecosia.org as default searcch engine | 2 | 461 | December 27, 2020 | |
Use custom Search Engine as default in Address Bar / Omnibox search | 3 | 2882 | August 25, 2019 | |
Is there a function to select my added search engine as a default in the URL bar? | 5 | 1123 | August 15, 2020 | |
Adding new search engines (SearX) and setting them to default problem | 3 | 12759 | May 5, 2022 | |
Can't add custom search engine | 0 | 38 | July 17, 2025 | |
How do I make a custom search engine the default search engine?
2 | 865 | August 5, 2019 | |
Search engines - ability to customize your ownd
3 | 366 | February 6, 2020 | |
I’m unable to change the default search engine (or even set one initially) | 2 | 249 | June 10, 2025 |
