Can't set ecosia.org as default searcch engine
NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._
I added ecosia.org as “other search engine” but when I click on the … to the right of ecosia.org, the “add as default” option is grayed out, so I am unable to set ecosia.org as the default search engine.
Is there some way to use ecosia.org as default? (they plant trees when you search - good for the environment!)
This may help https://support.brave.com/hc/en-us/articles/360017479752-How-do-I-set-my-default-search-engine-
