Hi Brave Support Team,
I’m writing to report a UI issue in the Shield menu. The interface appears to be broken, making it difficult to use and understand the available options.
Specifically, the problem seems to affect the layout and/or visibility of elements in the Shield menu, which impacts the overall user experience. I wanted to bring this to your attention in case it is a bug that needs fixing.
Let me know if you need any media attachment.
Brave Version( check About Brave):1.98.60
Mobile Device details: redmi note 9 pro max
