i am watching a livestream on youtube and i reached 5.2gb memory leak before the tab crashed, now i restarted, disabled gpu acceleration, enabled memory save, it’s still remping up. it’s at 3.4gb atm, i even have youtube premium so there’s no ad blocking interference, but for safe measures i did disable brave shields, still getting the memory leak.
Can you please try launching a Guest window (Menu --> More tools --> Guest window), close your original profile window (so only the Guest profile is open) and then test YT live stream there and see if you get the same memory usage?
On my end, on both macOS and Windows systems, I’ve had a YT live stream (1080p @60fps) going for about 10 minutes and only seeing ~400MB - 480MB memory usage:
Thanks for checking.
In digging into this I’m now seeing that I actually opened an issue for this some time ago that does not appear to have been resolved:
I went ahead and included your report in the Github issue and pinged some team members internally to take another look.
so far it doesnt go above 400mb but i only tried for 10~ minutes, how come disabling it then re-enabling it helped? ill wait a bit and come back to tell the result
sorry to necro but the problem is back, havent disable or enabled hw acceleration, but now it randomly crashes my tabs and it says it ran out of memory after hogging like 9gb ram
