Hey there, I’ve been facing memory leak problem in Brave while using YouTube, it doesn’t happen all the time, but it does more often than not. It renders my system completely unusable, I’ve 8 gigs of RAM so I’m already pretty constrained and I do developmental work so saving memory is crucial for me but this memory leak issue is very bothersome. I would really appreciate if this is looked into.
Thanks in advance!
Is this on Youtube Livestreams/Live Chat?
Not necessarily, happens on regular videos aswell
I’m experiencing the same issue, and the problem persists even in Incognito mode. Even with just a single YouTube tab open, RAM usage quickly reaches 4–5 GB or even more.
What I don’t understand is this: Brave blocks ads and trackers by default, so there shouldn’t be any need to install additional extensions. In theory, it should therefore run more smoothly and use less RAM than other browsers, but the situation doesn’t seem to be like that at all.
I really don’t understand what’s causing this. I hope this issue gets resolved as soon as possible.
