Memory leak with no extensions
The memory usage of “Extension: Brave” gradually creeps up over time.
I watched a bunch of videos on youtube and when I periodically checked the task manager its memory usage was higher each time
10-15 minutes later minutes later
it’s using more than 1gb of ram with nothing open
laterer
Even Vivaldi uses less ram than Brave after a while of browsing because it doesn’t leak
Every time I use the browser
Windows 11
Version 1.39.122 Chromium: 102.0.5005.115 (Official Build) (64-bit)
@pcmasterrace609 , @Chocoholic
Ref. material:
I have noticed this many times and there currently is only one fix… Shut down computer and restart. This will fix the issue for 3-7 days before it starts becoming an issue again and Brave will start memory leak, crashing tabs etc. I have 32gb of ram and my pc used to be able to have over 200x tabs open no issue with other browsers like waterfox 64. Brave on the other hand has issues with more than 30-40 tabs.
