Settings with alternate keyboard layout when adding custom shortcuts
The issue happens when trying to add a new custom keyboard shortcut, in my case one to activate extensions
1.) Add a custom keyboard shortcut
2.) When trying to add one that conflicts either with the keyboard on qwerty and the custom (my case dvorak) both of them are considered taken, not allowing me to use the shortcut
Example: When using Meta + Shift + X for extensions, the Meta + Shift + B for bookmarks prevents it from being activated along with it showing the qwerty layout of the keyboard
Brave Version: 1.69.160
Current workaround, I have a keyboard that can on it’s end that can trigger the dvorak keys preventing that from happening
