I own a 60% keyboard and have been using shift+escape as double quotation marks, but as I cannot change the keyboard shortcuts of brave, everytime I try to use double quotes the task manager starts.
I loved using brave so far and this is my only issue with it, but as I need to use double quotes quite a lot, I’ll have to stop using Brave until this issue is solved
Try going directly to the url for editing shortcuts: brave://settings/system/shortcuts
