Heyho,
Iam a total newbie β sorry in advance
I would like to save cookies for a few websites (YouTube, Twitch etc), while having all the others deleted after I close Brave. Is there a way to do it?
Thx
@ROKKSTAR ,
So unfortunately this exact functionality is not yet possible β however, we do have an open issue to add this feature down the line. Iβve added your report here as a +1 on your behalf and will ping the team to see if I can get any updates on the status of the issue:
opened 09:47PM - 26 Jun 20 UTC
enhancement
feature/global-settings
design
priority/P4
feature/settings
OS/Android
OS/Desktop
<!-- Have you searched for similar issues? Before submitting this issue, please β¦ check the open issues and add a note before logging a new issue.
PLEASE USE THE TEMPLATE BELOW TO PROVIDE INFORMATION ABOUT THE ISSUE.
INSUFFICIENT INFO WILL GET THE ISSUE CLOSED. IT WILL ONLY BE REOPENED AFTER SUFFICIENT INFO IS PROVIDED-->
## Description
As it is now, any data type that is checked in the `Clear browsing data --> [On exit]` will have _all data_ of that type removed upon closing the browser. While this is the intended function, we should implement a function similar to what Microsoft Edge does, where site exceptions can be added to a "Do not clear" list. Data on this list is ignored when the browser runs "clear on exit":
This would help users maintain login data for sites they regularly visit and not have to re-authenticate every time data is erased. Additionally, this helps with support, since clearing browsing data often resolves issues with bad cache data -- having the ability to suggest users do this, but without sacrificing specific data they know they want would be very useful and appreciated by users
## Miscellaneous Information:
Original thread that bought this to my attention (again):
https://community.brave.app/t/delete-all-cookies-on-exit-except-allowed-list/137872/5
