I would like to be able to clear all cookies automatically on exit EXCEPT for a specific list of cookies that I would like keep (that is, survive the exit and be available for next Brave session after exit). How can I do this in Brave?
Version 1.26.74 Chromium: 91.0.4472.124 (Official Build) (64-bit)
You can’t do that as of the moment, but there is an open Github ticket that aims to push for such a feature in the future.
opened 09:47PM - 26 Jun 20 UTC
OS/Android
OS/Desktop
design
enhancement
feature/global-settings
feature/settings
priority/P4
<!-- Have you searched for similar issues? Before submitting this issue, please … check the open issues and add a note before logging a new issue.
PLEASE USE THE TEMPLATE BELOW TO PROVIDE INFORMATION ABOUT THE ISSUE.
INSUFFICIENT INFO WILL GET THE ISSUE CLOSED. IT WILL ONLY BE REOPENED AFTER SUFFICIENT INFO IS PROVIDED-->
## Description
As it is now, any data type that is checked in the `Clear browsing data --> [On exit]` will have _all data_ of that type removed upon closing the browser. While this is the intended function, we should implement a function similar to what Microsoft Edge does, where site exceptions can be added to a "Do not clear" list. Data on this list is ignored when the browser runs "clear on exit":
This would help users maintain login data for sites they regularly visit and not have to re-authenticate every time data is erased. Additionally, this helps with support, since clearing browsing data often resolves issues with bad cache data -- having the ability to suggest users do this, but without sacrificing specific data they know they want would be very useful and appreciated by users
## Miscellaneous Information:
Original thread that bought this to my attention (again):
https://community.brave.app/t/delete-all-cookies-on-exit-except-allowed-list/137872/5
@jeffsklar ,
Left a “+1” on the github issue on your behalf as well.
This feature request was made long ago and still nothing. It’s shameful how basic Chromium features have been neglected. Most energy goes to Brave Ads and bloated features that most users don’t want or make use of.
system
Closed
August 15, 2021, 2:59am
5
