Remove search engine from Quick Search Engine list
I can’t delete search engines from the Quick Search Engine page.
There’s only an option to turn the engine on or off. I didn’t add these search engines and don’t want them permanently in a list.
Application version Brave 1.80.122, Chromium 138.0.7204.157
Operating system Android 15; Build/AP3A.240905.015.A2
Since I can’t add a reply, I will edit the post to say thanks Mattches for your lack of help. Perhaps you should read posts properly before adding irrelevant unhelpful answers. Maybe leave the support to someone else instead of just trying to inflate your post count.
In Brave on Android, go to Settings --> Search Engines --> Quick-search Engines and toggle on/off the ones you want or don’t want.
