Purchased USDC through Brave Wallet, but it's not showing in wallet despite etherscan confirmation
Description of the issue: I purchased $483.26 of USDC via Brave Wallet. The etherscan hash shows sthe transaction as successful, but it’s not appearing in my brave wallet.
Is the issue occurring on a specific network? Ethereum
What operating system are you using? Windows 11
Brave Version (check About Brave): v1.78.102
Hello - Please check to see if its set as a visible asset under your filters. You may need to add it manually. If so, instructions to add the token contract can be found below.
https://support.brave.com/hc/en-us/articles/20643855700109-Adding-a-Custom-Token
USDC Contract Details: https://etherscan.io/token/0xa0b86991c6218b36c1d19d4a2e9eb0ce3606eb48
Let me know if you have any questions. Thanks!
I should note that - when I try to manually add a custom asset - I get a message telling me the token has already been added to my portfolio…only it hasn’t.
Please check the Visible Assets section to see if it’s set to visible.
I’m not sure what happened, but it suddenly appeared. I had turned off my laptop after making the post and when I came back to try the steps you suggested, the assets were showing. I waited over an hour after the etherscan confirmation and then restarted my laptop, but that didn’t help so I ultimately made the post. It’s my first foray into crypto, so I was sure I did something wrong. I guess not (other than not waiting long enough. In any case, thanks so much for your super quick response and information. Much appreciated!! :handshake:
