USDC not showing up
I was sent some USDC as a test before I receive a larger payment. The transaction is here. Despite it being sent 30 minutes ago, still nothing is showing up for me in my brave wallet.
Okay, using the mnemonic phrase, I accessed the wallet using MEW, and the $5 did show up. Not sure what’s up with the brave wallet interface.
Okay, I sent some ETH to the wallet since I needed it to withdraw the USDC, and that doesn’t show up on the brave wallet either! only on MEW.
@Mason,
Thank you for reaching out. It sometimes takes a moment for the UI to update – have you restarted the browser since making the transaction?
I don’t think I have. I have a lot of things open right now so I’d rather not restart right now, but I’ll restart it at some point, and when I do I’ll let you know the result.
I have restarted the browser, it does not show up. Something that is worth noting is that it actually didn’t let me log into the wallet with my password - it just says something like “network request failed”. Then if I refresh the page it lets me into the wallet and never asks for my password again.
@Mason,
Apologies for the late reply. I’ve reached out to the team for more information here – can you also tell me:
  • What Brave version you’re using (Menu --> About Brave)?
  • What Operating System you’re using?
  • What wallet version is showing in brave://extensions?
  • version: Version 1.25.68 Chromium: 91.0.4472.77
  • os: NixOS 21.11.20210604.1ca6b0a
  • wallet version: 1.0.32
@Mason,
According to the Etherscan transaction, your balance should be zero, as you sent in 5, the n 85, then 90 “OUT” – but I may be misunderstanding the exact situation here:
You are correct, I no longer have any USDC there, but in order to transfer it out, I had to add some ether to that address, which also doesn’t show up in brave.
