Problems When Closing Other Tabs
I have installed Brave and have disabled Vertical tabs but face an issue when attempting to right click to close other tabs or tabs to the right as the last entry is “use vertical tabs” which I keep catching and above that I find bookmark all tabs. How can I get rid of these ill placed options?
So you don’t see these options when clicking on a tab?
That is the problem I keep catching that lhat last option as I am used to the closed tab options to be last in the list as they are in Firefox
Yes, in Firefox, closing tabs is towards the bottom:
Unfortunately, there is no way to remove the bookmark and vertical tab context menu items.
Additionally, this is not a “bug”, as you have labelled it. This is a Brave feature, and it works as intended. You cannot extensively customize Brave so as to remove context menu items, for example.
I would recommend that you get used to the different order of right-click context menu items, as they are a Brave feature.
So whoever designed this dogs breakfast is a braindead idiot who should be publicly idenified and jaledl Brave uninstalled - UTTER JUNK
“whoever designed this dogs breakfast”
Brave is not a “dog’s breakfast”. Do not expect Brave to fulfill your every tiny need and preference. Just because Brave doesn’t have the context menu items in the “right” order doesn’t mean you have to ditch the browser. Simply middle-clicking on the browser tab can close it, no thought required.
“a braindead idiot who should be publicly idenified and jaledl”
Brave Software was founded by Brendan Eich and Brian Bondy in 2015. Eich is known for creating JavaScript and co-founding Mozilla, while Bondy has a background in engineering from Khan Academy and Mozilla.
I’ll point out that Mozilla is the very same company that makes your absolutely awesome Firefox browser! Both individuals are highly respected in what they do.
“Brave uninstalled - UTTER JUNK”
Good luck, it’s obvious that Brave isn’t the right browser for you.
If it makes you feel any better, I’m writing this message on Firefox. I volunteer in the Firefox support community too, not just the Brave community. I’m happy to help anyone with web browser questions/issues.
@FwedFwuppe
I have not tried the following, but it may interest you.
Instead of right-clicking (muscle memory issue), a suggestion: AutoHotKey v2 > ‘https://www.autohotkey.com/’
To Close Other Tabs, you would:
  1. Select a tab
  2. Use Hotkey: Ctrl + Alt + O
An AutoHotKey (“AHK”) script follows.
#Requires AutoHotkey v2.0
; Brave Browser - Close Other Tabs
; Hotkey: Ctrl + Alt + O
^!o::
; Ensure Brave is active
if !WinActive("ahk_exe brave.exe")
MsgBox "Brave Browser is not active."
return
; Open tab context menu for focused tab
Send "+{F10}"
; Wait for menu to appear
Sleep 200
; Move down menu items
; Adjust the number if needed
Send "{Down 6}"
Sleep 100
; Select "Close other tabs"
Send "{Enter}"
It still seems rather odd that if a user turns off Vertical Tabs in the settings that this option is presented in the way it is. Seems to suggest that the developer was/is mentally challenged and hadn’t thought things through.
It provides an easy way for the user to enable vertical tabs if they wish, rather than digging in the settings.
