Not able to connect brave wallet to brave rewards
Brave 1.86.146
Windows 11
Who is your verified custodian or self-custody? (Uphold/Gemini/bitFlyer/Solana)
self custody
yes
What error or behavior are you experiencing? Do you have atleast $1 of SOL on the account?
There is over $1 in SOL in the account I’m trying to connect.
My account is too new to upload the screen recording I made.
The issue is that neither the connect nor back button work at all. My touches don’t seem to register.
Just like my problem .there’s lot add already but cant connect..wrote feedback 2 months ago but seem brave browser don’t care .no reply or anything like something
@countll if you previously connected your Solana address four times, you’ll need to use a new Solana address for new Rewards connections.
Thanks for responding. This is the first time I’m trying to connect my rewards to Brave wallet.
After some more testing, I found I can’t click connect or back once the wallet connect pop-up shows on a few sites I’ve tried.
Solved, sort of.
I disabled every app that can draw over other apps which allowed me to press the Connect button/label.
I only realized that may be the problem after I couldn’t allow a different site to use my location. That pop-up notified me that I couldn’t allow the location access due to bubbles or overlays.
This is a bug report now: if you can’t select a wallet account due to overlays, let the user know that.
@djk - Could you let me know what special access and apps you had set under Settings –> Apps –> Special Access?
The apps I have that allow drawing over other apps are:
  • 3C all in one toolbox
  • Automate
  • Google
  • Google Play protect services
  • Phone
  • Termux
I suspect the main culprit is 3C because I have a status bar overlay that shows system info.
I want to insert 1$ into for creating bat account
How do I do that ?
