NordPass in Brave: authorization header not provided
I’ve been using Brave for some time and always used the NordPass extension as password manager. As of today I can no longer log in. I get the error: “Authorization header not provided”. It is still working on other browsers.
Any idea how to solve this problem?
Thanks :slight_smile:
I tried it and it worked. Thank you for the suggestion. :slightly_smiling_face:
Alright, same issue here. Worked fine for months but recently had the authorization problem. Reinstalled the extension yesterday - worked fine - but now it’s having the same issue. Either Brave or Nordpass made an update that is causing an issue. Reinstalling the extension every day is not a solution.
