Multi select tabs not working in brave using ctrl+left click or shift+left click using vertical tabs
I have the latest version of Brave v1.98.60 and latest version of windows too. When I try to select multiple tabs using ctrl+left click or shift+left click it just switches to the second tab instead of selecting both of them I looked everywhere to fix this issue but nothing works.
Seems to be working for me in the latest build on both Windows and macOS systems. Can you confirm if you’re still seeing this issue?
