Microsoft Teams problem
https://teams.microsoft.com/_#/
Did the issue present with default Shields settings? (yes/no) No
**Does the site function as expected when Shields are turned off? No **
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): No, I don’t think
Does the site work as expected when using Chrome? Yes and it works on Edge
Version 1.19.90 Chromium: 88.0.4324.146 (Official Build) (64-bit)
