Long-press on YouTube brings up context menu instead of speed control on mobile
Even after deleting and reinstalling the app, the context menu still appears when I long-press on YouTube. I want to watch videos at 2x speed.
I am using the mobile app, so the ‘Advanced’ option does not appear in the settings. In the Brave Shield tab, the option ‘Show context menu on long press’ is not visible either. Please provide a solution
  1. Open Brave on mobile.
  2. Go to youtube.com.
  3. Play any video.
  4. Long-press on the video screen.
Expected result: The video playback speed should increase to 2x.
Actual Result: A context menu appears.
Brave Version( check About Brave): Brave 1.81.131, Chromium 139.0.7258.66
Mobile Device details
Samsung Galaxy Note20 Ultra, Android 13
Additional Information: This problem started after I cleared my Browse history. Everything was working normally before that.
@jjh992 already been discussed and is a known issue. You can see a workaround at Brave Beta Android’s “context menu” is interfering Youtube’s 2x play speed when pressing the video - #6 by Saoiray
