On YouTube, the playback speed menu randomly breaks.
It shows only one option: “4x” and all other speeds (0.25x → 2x, Normal, Custom) are missing.
Restarting Brave temporarily fixes it, but the issue returns after some time.
https://www.youtube.com
Yes.
Partially — turning Shields OFF sometimes restores playback speed options,
but the issue returns again later even with Shields OFF.
Yes.
Enabling Fingerprinting protection (Strict / Block) consistently causes YouTube to lose playback speed options.
Even after switching fingerprinting back to Standard, the problem sometimes continues until Brave is restarted.
Yes — all playback speeds appear normally in Chrome, Edge, and Firefox.
Issue occurs only in Brave.
Brave is up to date
Brave 1.84.141 (Official Build) (64-bit)
Chromium: 142.0.7444.176
