I’ve selected llama-70B in my settings but Brave keep choosing Claude for Leo. When I open new pages, they are set to Claude. When I ask from the URL bar, Leo is set to Claude. I tried restarting the browser, and also clearing Leo’s data from the settings and setting it up anew to use llama-70B.
Thanks for the report. Will make sure the team sees this along with your other feedback. Will respond when we have more information for you.
@Tritonio,
That open issue does appear to be what you’re describing — can you tell me what the difference is?
The issue mentions:
Current behavior is that it only affects new tabs.
But for me it affects nothing at all. It keeps using Claude for everything regardless of what I select in that setting. I have to manually change it every time in the conversation for it to use llama.
FWIW, the latest update that added MIxtral, also fixed this issue for me.
Thank you for confirming
