Drop-down menu and "load more button" not functioning!
When I go to the website main page everything works fine, but when I go to a video page, the “Load More” button and “drop-down menu” won’t respond.
Up until a few days ago (Feb 14) I never had this issue. Other things have happened to my computer since then but other browsers seem to run it fine.
(It’s a porn site watch out!!)
https://www.thumbzilla.com/
Did the issue persist with [default Shields settings]?
Yes
No
I tried a bunch of different settings to fix the problem. Before that I had not changed any settings in Brave.
I did away with Chrome a long time ago and don’t feel like reinstalling it just for this test, but the site worked fine on Firefox and Internet Explorer.
[Version 1.3.115 Chromium: 80.0.3987.87 (Official Build) (64-bit)]
Like I said before, until just yesterday I did not have this problem, and other browsers work fine right now but Brave has the issue. I’ve tried with and without brave shield on, and other site permission settings. It doesn’t work. I’ve attached a SAFE picture of what the “Inspect element” came up with, which was 3 errors on the page. I can’t make sense of it or even know if it’s related to my issue but the main page (which doesn’t have an issue displaying the drop-down menu and load more button) doesn’t have these errors. Thank you for the help and sorry for having to use a site like this in my support ticket.
Seems to occur in Chrome also, Works in Mobile mode however (Adjusted UA). I would say this a site issue, the webmaster should re-check their site with Brave/Chrome.
Just an update: It seems that if I stay on the page for a few minutes the buttons begin to function again. Quite the odd problem…
